Error Bug in Case structure LabVIEW 2019
I think I found a bug in LabVIEW 2019 with the new adding multiple case structures.  If I created a default and an Error 1 case and wire an error with a code of 0 the Error 1 case fires.  If I have more Error cases the code runs as expected.  I have attached a vi that illustrates this problem.
Dan Shangraw, P.E.
(4,233 Views)
Hello ASTDan,
I was able to see the behavior in my side, and have filed CAR 739174 to track it.
(4,210 Views)
FYI the bug appears to be specific to wiring an error constant to the selector. It does not happen when wiring an error control, or an error value propagated from a non-constant source upstream.
(4,158 Views)
Accepted by ASTDan
For anyone following this thread, the bug has been fixed in the LabVIEW 2019 f1 patch: LabVIEW 2019 Patch Details
(4,030 Views)
Thanks!
Dan Shangraw, P.E.
(4,016 Views)
