Error Code 1 when attempting to build an exe
Good Morning;
I have "inhearated" some code.  I am attempting to get it at least readable.  I know it has come a long way and still has quite a way to go.
when I attempt to buile an exe i get the following error:
Error 1 occurred at AB_Source_VI.lvclass:Close_Reference.vi -> AB_Build.lvclass:Save.vi
Possible reason(s):
LabVIEW:  An input parameter is invalid. For example if the input is a path, the path might contain a character not allowed by the OS such as ? or @.
NI-488:  Command requires GPIB Controller to be Controller-In-Charge.
I have been looking at my close refreences and file saves.  I am drawing a blank....
I have found simillar posts, but nothing.....
Michael C. Nedrow
Message 1 of 8
(4,321 Views)
check out the solution in this thread and see if it helps you.
https://forums.ni.com/t5/LabVIEW/Getting-Vague-Build-Error-When-Making-Executable/m-p/3196611#M92637...
aputman
Message 2 of 8
(4,311 Views)
Well shoot, no luck.  I even changed my destination to a new location.   Same thing.
I am digging through the build log now.
Thank You for the attempt!
Mike
Michael C. Nedrow
Message 3 of 8
(4,306 Views)
I do not see anything in the build log.
After the last one in the list it just lists the error.
Michael C. Nedrow
Message 4 of 8
(4,288 Views)
Unfortunately, i can't open the file to look at the code.  Does the VI run in developer mode, but won't build?
aputman
Message 5 of 8
(4,274 Views)
That is correct..
Michael C. Nedrow
Message 6 of 8
(4,265 Views)
I just tried to save a copy of this VI to my desktop so that I could cut different parts out of the spare copy.    I got the same input parameter invalad bad char. error.............strange
Michael C. Nedrow
Message 7 of 8
(4,258 Views)
Well this makes the brain hurt.........after i could not  save a copy, I exited LabVIEW, restarted the tool, and away we go....it is working.......I have done this approx. 3 times since I have been werstleing with this one.
Thank everyone for the time spent looking at this silly thing.
Mike
Michael C. Nedrow
Message 8 of 8
(4,248 Views)
