LabVIEW 2015 not seeing CAN ports...
My lab recently upgraded to LabVIEW 2015. I wrote a simple CAN loopback VI, but XNET in LabVIEW does not seem to "see" the interfaces. The interfaces appear in NI MAX as "CAN1", "CAN2", etc. Am I missing something?
Error code: -1074384758
(3,158 Views)
Did this work prior to the upgrade to LV2015? Which CAN hardware are you using? Are you sure your CAN device supports XNET, rather than the older NI-CAN? It might help to post a screenshot of MAX.
(3,153 Views)
The devices are PXI 8513s and they support XNET as they did with LV2014.
(3,148 Views)
It is working now. Not sure what I did. Thanks Sir...
(3,142 Views)
