Error Code 17600
I Hust trey to make a clone hard disk drive with xxclone software, after I finished my clone I start to receive this error, Could you please tell me how I can Fix this error:
I really appreciate all support that you can provide me.
Error
Error loading step 'Connect to programmer box' of sequence 'MainSequence' in file 'AP3 Prog Test 1_0_5.seq'.
The prototype of VI 'C:\_projects\OPTEK Technologies\Production Test System\Working\Source code\LabVIEW\Programming Wrappers\Init_StartComm.vi' changed.
The prototype needs to be updated before executing the VI.
To update the prototype, open the Specify Module dialog.
Failed to load a required step's associated module. [Error Code: -17600]
OK
(3,452 Views)
(3,424 Views)
IT Support,
What version of TestStand are you using? and also the version of LabVIEW that was used to create the original VI?
Have you also tried removing the Init_StartComm VI from the Specify Module Dialog within your MainSequence and tried re-adding it back in?
Also, does the sequence run correctly on the source drive from which you cloned?
Raj
(3,411 Views)
