I am trying to record time during my measurements but can not see values in Excel
I am not very familiar with Labview yet and trying to record some pressure values, flow rates versus time. However, when I save the values and open the output Excel file, I can not see the correct time and date values. Both time and date formats are not correct. In the attachment, I am sending the view of the block diagram, front panel and the Excel file I obtained.
I will be very glad, if you could give some suggestions.
Thanks in advance.
S
(3,998 Views)
I'm assuming that you are writing to the file as text.
The first thing I'd check is the cell formatting in Excel. I ran a quick check of using the "write to measurement file" express vi to write an empty dataset to a text file and saw the data and time looking wrong. A quick check in Exvcel showed that the data in an unexpected format, but appropriate use of Excel's "format cells" fixed it.
Rod.
(3,981 Views)
PS
For your application, write to measurement file is probably not the best way of writing the data.
It's very hard to see what's going on when you use express vis, have wires entering and leaving objects at other than the terminals, and you only shows us a screen dump.
Rod.
(3,970 Views)
This may help:  http://digital.ni.com/public.nsf/allkb/04BA60F0C2DE768A86256CED007E528B
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(3,949 Views)
S
Excel and LabVIEW keep time differently.  You will need to translate the value LabVIEW uses as time to the value Excel uses as time.
Here is a good routine:Time to XL.PNG
(3,943 Views)
