Error Handling
Hello, I have a vi that works fine except for the error handling. The vi was made in Labview 7.0. Could anybody tell me what the problem is?
Nevica
(2,977 Views)
Accepted by nevica
If you have anything, which in this case is an error cluster, that reads from a case structure,
there must be a value in every case.
In your -1, default, case you do not have anything leading to the error cluster.
Cory K
(2,974 Views)
