Error Labview 2010 installation
I get an error when i am installing LabVIEW on a System with : WinXP SP3. I tried this by starting the setup. The autorun.exe cannot start (Signature: ErrorEventType : InPageError     P1 : c000003c     P2 : 00000005   )
I have all the versions (from LV7.0 to LV2009SP1) installed on my Computer.
Can Anybody Help?? (i have already LV2010 on my laptop with Win7. but i need it on my computer also)
A million thanks for any help.
RENN
Kudos always welcome for helpful posts 🙂
(3,883 Views)
You can solve this problem by going to Start » Run and typing: regsvr32 C:Windows\System32\msi.dll .  Press OK and your installation should be working.
Cheers,
Philip
(3,846 Views)
Hi Philip,
Thanks a lot for your reply!
could you please explain me why this happens and why should i register this dll.
Note: after running the command i got another error (Load Library error). dll not found. But its already in System 32.
RENN
(3,842 Views)
Do you use a 32bit or a 64bit version of Windows?
(3,835 Views)
OS: XP >> Version 5.1.2600 SP3 32 bit
Processor: Athlon 64 X2...
(3,832 Views)
which regional settings are you using in Windows XP? Have a look at this post: http://forums.ni.com/t5/Multifunction-DAQ/Installation-of-NI-USB-6259-Visual-C-Runtime-Library-Runti...
Can you please report me if you could solve the problem by changing your reginal settings?
Cheers,
Philip
(3,790 Views)
