How i can use "GET Trace List" in labview
    For Extraction of data from Citadel, i am using Get Trace List from DSC module in LV8.6. I am facing problem and getting error while running this function. It gives an errror for  "database URL" input. According to HELP of LV. I have to give computer name in my case SBCPC and data base name "vishnu". So i am giving //SBCPC/vishnu. When the function run it is giving error that input should be in form of  //SBCPC/vishnu/T1  where T1 is my network variable which is i am logging.
Can any buddy give me Idea to how to use "Get Trace List"
(2,760 Views)
Take a look at the Browse Database.vi in the DSC section of the block diagram. The output of this should be in the format that you need.
(2,735 Views)
Thanks.
Here with Browse Database.vi I have same error. Here screen shot of that. The same value //SBCPC/vishnu i am getting when i am probing to Browse Database.vi output.
What could be the reason for this error.
(2,719 Views)
