Error Message
When i do a program build the next time i open labview i get an error message. The log file showed the follwing details:
#Date: 18 Oct 2016 15:02:21
#OSName: Windows 7 Professional Service Pack 1
#OSVers: 6.1
#OSBuild: 7601
#AppName: LabVIEW
#Version: 13.0.1 32-bit
#AppKind: FDS
#AppModDate: 01/09/2014 16:39 GMT
#LabVIEW Base Address: 0x00400000
starting LabVIEW Execution System 2 Thread 0 , capacity: 24 at [3559644148.22320990, (15:02:28.223209858 2016:10:18)]
starting LabVIEW Execution System 2 Thread 1 , capacity: 24 at [3559644148.22320990, (15:02:28.223209858 2016:10:18)]
starting LabVIEW Execution System 2 Thread 2 , capacity: 24 at [3559644148.22320990, (15:02:28.223209858 2016:10:18)]
starting LabVIEW Execution System 2 Thread 3 , capacity: 24 at [3559644148.22320990, (15:02:28.223209858 2016:10:18)]
<DEBUG_OUTPUT>
18/10/2016 15:03:28.319
DWarn 0xD1EED773: Nonfatal insanity (0x00000080) detected in'S2 Main program.vi: My Computer Build Context'
e:\builds\penguin\labview\branches\2013\dev\source\panel\fpsane.cpp(1132) : DWarn 0xD1EED773: Nonfatal insanity (0x00000080) detected in'S2 Main program.vi: My Computer Build Context'
minidump id: f69f7fdd-457c-44db-92bf-70b792e54264
$Id: //labview/branches/2013/dev/source/panel/fpsane.cpp#16 $
</DEBUG_OUTPUT>
0x006A3C93 - LabVIEW <unknown> + 0
0x10014DF0 - mgcore_SH_13_0 <unknown> + 0
0x00D53EF2 - LabVIEW <unknown> + 0
0x00CD5A84 - LabVIEW <unknown> + 0
0x00DE7E0B - LabVIEW <unknown> + 0
0x00E029FF - LabVIEW <unknown> + 0
0x00CD5820 - LabVIEW <unknown> + 0
0x00EB4B21 - LabVIEW <unknown> + 0
0x00DBA48A - LabVIEW <unknown> + 0
0x00FCD432 - LabVIEW <unknown> + 0
0x010B82F2 - LabVIEW <unknown> + 0
0x010C1DA0 - LabVIEW <unknown> + 0
0x010C37AF - LabVIEW <unknown> + 0
0x010C4121 - LabVIEW <unknown> + 0
0x010C44B8 - LabVIEW <unknown> + 0
0x01789CFD - LabVIEW <unknown> + 0
0x013067A4 - LabVIEW <unknown> + 0
0x00656996 - LabVIEW <unknown> + 0
0x00656A62 - LabVIEW <unknown> + 0
*** Dumping Bread Crumb Stack ***
*** LabVIEW Base Address: 0x00400000 ***
#** Saving: "C:\Users\dkeating\Desktop\S2\LabviewB\builds\S2 Project\S2 Program\Application.exe\Users\dkeating\Desktop\S2\LabviewB\S2 Main program.vi"
*** End Dump ***
Last sanity check run time for the VI: 0ms
Insane object heap info:
flags=0x800
owner=0x1CC14CB0
sequenceList (0x1CC126E0): n=1: 1CBC06CC,
label=0x00000000
description=0x00000000
bounds= tlbr(380, 1470, 451, 1560)
Undo stack (oldest to most recent):
Insane object at BDHP+1CC12718, UID 13097, in "S2 Main program.vi": {graphics } (0x80): Flat Sequence Structure (FLAT)
<DEBUG_OUTPUT>
18/10/2016 15:03:30.523
minidump id: cbf78827-e67c-4096-b49f-d3840b7e48dc
</DEBUG_OUTPUT>
0x00FCD96C - LabVIEW <unknown> + 0
0x005C0CAE - LabVIEW <unknown> + 0
0x005C1E00 - LabVIEW <unknown> + 0
0x005BF0AD - LabVIEW <unknown> + 0
0x005BF8D0 - LabVIEW <unknown> + 0
0x005C1882 - LabVIEW <unknown> + 0
0x012C56A5 - LabVIEW <unknown> + 0
0x01335739 - LabVIEW <unknown> + 0
0x0133E8A6 - LabVIEW <unknown> + 0
#** compile: "C:\Users\dkeating\Desktop\S2\LabviewB\builds\S2 Project\S2 Program\Application.exe\Users\dkeating\Desktop\S2\LabviewB\S2 Main program.vi"
*** End Dump ***
flags=0x800
owner=0x1CC14CB0
label=0x00000000
stopping LabVIEW Execution System 2 Thread 0 , capacity: 24 at [3559644248.08592180, (15:04:08.085921765 2016:10:18)]
stopping LabVIEW Execution System 2 Thread 1 , capacity: 24 at [3559644248.08592180, (15:04:08.085921765 2016:10:18)]
stopping LabVIEW Execution System 2 Thread 2 , capacity: 24 at [3559644248.08592180, (15:04:08.085921765 2016:10:18)]
stopping LabVIEW Execution System 2 Thread 3 , capacity: 24 at [3559644248.08592180, (15:04:08.085921765 2016:10:18)]
Possible path leak, unable to purge elements of base #0
Any help would be greatly appreciated;
Barry
(4,322 Views)
It looks like there is an issue with that flat sequence structure - is it necessary? Could you use dataflow instead to order the operations? If not - try re-creating it and see if that helps. It might be that something in the properties of it has become corrupted.
You should also show us your VI in case you are doing something which might indicate why you have a problem.
(blog)
(4,315 Views)
Are you receiving any errors while running or building code or is LabVIEW just letting you know that there was a "problem" last time it ran? The warning that is coming up is described in a bit more detail in the KB below.
http://digital.ni.com/public.nsf/allkb/AFA28DCC3DE89839862566B200594E8C
Usually DWarns aren't a big deal but if you want to get rid of the insane objects you can try following steps to find and delete the problem object.
http://forums.ni.com/t5/LabVIEW/Insane-object-at-BDHP-256D8-in-quot-vi-quot-graphics-0X80-wire/m-p/2...
(4,306 Views)
