Messages between sub Actors in Actor Frame
With Actor Framework, I want to create 3 Actors: Controller, Viewer, Model.
 Controller is the Root actor to launch Viewer Actor and Model Actor.
I want to build the message from Model to Viewer.
How can I do?
(3,067 Views)
The Actor Framework purposefully wants all subActors to have to go through the parent Actor in order to pass messages around.  So you need to send a message to the controller who will then pass it on to the Viewer.
(3,006 Views)
