Error : No of digital outputs written and read are different
testdev:
How are you updating the other VI? Are you using using VI Server functions inside a case structure to do so?. Without looking at your code, I cannot give you much suggestion. The two subVIs that you attached did not reflect the behavior.
Rudi N.
Message 11 of 13
(516 Views)
Yes..I am using VI server references inside the case structures.However, I fixed the problems.Everything is working fine now. Thanks
Message 12 of 13
(513 Views)
testdev:
I am pleased to hear that things are working fine now. Please feel free to post again if you run into any difficulties.
Rudi N.
Message 13 of 13
(506 Views)
