Error Number -2147467259...Any ideas?
LV 7.1.1, TS3.1
I have written a operator interface for teststand...And this is the last litle gremlin hidding away in the software. Its an intermittant problem taht only happen at the end of a test when using the parallel model (ie 2+ tests runing at the same time..
The vi that could generate this message are re-entrant which is a pain to debug.
Any idea what this error number means?
(2,679 Views)
You can check out the post refernced here:
http://search.ni.com/query.html?col=alldocs&qp=%2Bcontenttype%3Acommunitydiscussions&layout=Exchange&qt=2147467259
Cyril Bouton
Active LabVIEW Developper
(2,665 Views)
