i want to read data from spread sheet?
please help
(2,696 Views)
Use Read From Spreadshee File.vi
Search LV help, many examples for reading/writing to spreadsheets in numerous formats.
(2,689 Views)
Reading directly from a binary excel file (I'm assuming that is the spreadhseet app you are using), is fairly involved. It can be done, and there is source code available from the open-office project to guide you. As Analog implied, if you were to save your spreadsheet (save a copy) as a text file, it is really easy to read it in. However, that instance of the spreadsheet will lack equations, sheets, and any of your graphs.
Sheldon
Technical geek, engineer, research scientist, biodegradable...
(2,672 Views)
