Error Out Message - database Connection
Hi there
I need your help. I just got this error out message when i create a table using MS Access database.
 NI_Database_API.lvlib:Conn Execute.vi->NI_Database_API.lvlib:DB Tools Create Table.vi->Untitled 3<ERR>ADO Error: 0x80040E14
Exception occured in Microsoft OLE DB Provider for ODBC Drivers: [Microsoft][ODBC Microsoft Access Driver] Syntax error in field definition. in NI_Database_API.lvlib:Conn Execute.vi->NI_Database_API.lvlib:DB Tools Create Table.vi->Untitled 3
I am a be gainer to lab view data, what should i do to solve this problem ???
Rd
Ganesan
(4,054 Views)
Accepted by erganesh
@CPUT wrote:
Hi there
Rd
Ganesan
As you were told at http://forums.ni.com/t5/LabVIEW/what-error-is-this/td-p/2028382
the way to solve this problem is to learn SQL
This is not a problem with LabVIEW.
(4,049 Views)
