Error SISO-OFDM NI USRP 2920
Hello, I'm having a trouble with my LabVIEW. So I'm having a trouble when I'm trying to run Single Input Single Output (SISO) OFDM, the error output was "niUSRP Set Time.vi<ERR> The specified device name is not recognized" and the error code was -1074118614. For the hardware I'm using USRP 2920, and I'm using LabVIEW 18.0 x64 bit. This error also appears on the transmitter and receiver. I would be glad if you can help and assist me to solve this problem, thank you very much
(964 Views)
Hi n0psl0l0l
As you have seen in the error description it says "the specified device name is not recognized" which means, that you should double check your device name with you want to use for this VI.
Regards)
(918 Views)
