Error code 1, identifying the invalid parameter, output to a text file
I am using labview to record information from a load cell.  I have building a file path set up, data coming in and outputting in the wave chart and as a string, when trying to write it out as a text file nothing is being written.
Error out is giving me code 1.  The source is “Open/Create/Replace File in…”
There is an invalid input but as far as I can tell it is everything looks fine.
How do I identify the invalid input parameter?
What is causing this error?
(10,037 Views)
 Nice tag Ben.
As he will no doubt point out soon the "Create" constant should be "Open or Create"
Also, check that constant into Number to Fractional string-  You probably want more than 1 digit of precision.
(10,006 Views)
Could also be "Create or Replace".  Regardless, if you try to overwrite a file that already exists, you get error code 10.  Trying to create a file to a folder you do not have access to gives you error code 8.  Trying to create a file in a folder that does not exists gives you error code 7.  Typically error code 1 is due to an expired reference.  I am running out of ideas.
Could you post your actual VI so that we can attempt to debug it?
(9,993 Views)
Thank you for the input.
I've tried the "Open or Create" and "Open or Replace".  But it still yields the same result.
Open/create/replace file in
sub vi's program name.vi -> main vi's name.vi <APPEND>
C:\filename.txt
It does not seem to see the filename input from the main vi as a vaild input and I can't figur out why.
(9,972 Views)
Thank you.
If you would like to see the VIs they are attached.
C:\filename.txt
(9,969 Views)
Browse Options on your user controls.  These need to be set to browse for folders rather than files.  Set them with the property editor.
(9,944 Views)
Accepted by JonThorn
It was something else.  At the end of the filepath in the file path building vi I had a carriage return line feed at the end of the path.  Ben Noticed it.  I got rid of that and am now writing .txt files with no problem.
(9,938 Views)
