Error code 1026 after installing sensor configuration
Hello everyone !
I`m sorry in advance if somewhere in the forum have the same problem but I couldn`t find it and that`s why I`m writing this topic.
I made a sensor configuration on LabVIEW 2017 Version 17.0.1f3(32 bit). Machine that I`m using is with cRIO 9049 and Beckhoff CP72xx-xxxx-0060 | Economy Panel PC.
The LabVIEW program is on the IPC and I`m trying to install the sensor configuration from the IPC to the cRIO controller. The file with configuration is ASC file.
The problem is that after installing the file and updating the cRIO from the IPC it gives me the error 1026 and the program loses communication with the cRIO, the interesting thing is that after the error in the program I`m seeing that the configuration is loaded.
I did the same thing for machine configuration where the file is AMC and I don`t have a problem. I have tried a lot of rewriting the files from IPC to cRIO and deleting files but nothing helped, everytime I install the ASC file it gives error 1026 and loses communication.
So I`m pretty desperate and hoping someone can help and give some advice.
Thank you in advance!
Best regards
Message 1 of 1
(932 Views)
