LabView Compatibility with Jake AI
Hello all,
is there a compatibility matrix where you can see how the compatibility between LabView and Jake AI (from JKI, jki.net/jake ) is ?
With which LabView version does Jake AI work with?
As I understand, Jake AI is an separate installed program, right?
But I think there will be a compatibility matrix.
Thank you and BR
EWiebe
Eugen Wiebe
Bernstein AG
CLAD - Certified LabView Associate Developer
(2,222 Views)
The answer is:
For general question that do not require interfacing with LabVIEW, Jake can answer question about
"any" LabVIEW version. If you want to have Jake to interface with your LabVIEW version, you need LabVIEW 2020 or greater.
Jake desktop supports LabVIEW versions >= 2020, in both 32 and 64 bit.
Labview versions - Jake AI Help Center
Eugen Wiebe
Bernstein AG
(2,143 Views)
