read and write cluster from teststand to labview
hello!
I have a cluster type "Device_ID" variable under teststand. I have to read and write it from my labview HMI. I did the manipulation with strings and numericss (testand get property value.vi). I'm able to recover each variable from the cluster and rebuild it but not to recover it in its entirety (in a variant for example and then return it to the type). Is ti possible ?
Thank you
Message 1 of 1
(281 Views)
