Error code-63040 on CRIO
Hi everyone
I got this following code error  while compiling my FPGA code
and I d'ont see where I did a mistake
I am connected to my controler via Ethernet
I will be thankfull if anyone see where is the error
Thank you in advance
My best regards
Nadia
(5,177 Views)
hello Nadia,
Are the software versions on your crio the same as on your host pc?: http://digital.ni.com/public.nsf/allkb/B77CEB8067558F6F86257203007F1E91
I previously had problems with deploying to my FPGA (can't remember if this resulted in the same error) and resolved those by starting the NI-RIO server (under  windows services, there find the NI RIO server and start it)
Good luck,
Martijn
(deleted the fpga compile server stuff, this was related to another challange, got a bit lost in all the challanges)
(5,114 Views)
Thank u for ur reply.
I don't think the problem is the software versions,because my FPGA code wad deployed successfully, and once I tried to run my VI to see my variables I had the following message "Preparing for interactive execuion" and than the error
Best regards
(5,040 Views)
Accepted by topic author k.nadia
Here is the solution for my problem in the link below
How do I solve Error-63040
Good luck evryrone
My best regards
Nadia
(5,022 Views)
