Error code:The signal length is too small for computation, or the stimulus and response signals are not of the same length.
I want to downsample a input from the simulation block, somehow i always get an error when i run it, is there anyway i can fix it??
Thanks!
LabView 2011, windows 7.
(2,375 Views)
Hey Ivy,
The subVI you're using, "SI Down Sampling.vi", in your code is missing. So it makes it difficult to troubleshoot this type of problem. Also, in the future, it definitely helps if your provide a specific screen shot of the error your seeing and what part of the VI is generating the error. Is the error coming from something in your subVI or possibly the Signal Generator VI?
Tim A.
(2,363 Views)
