filter empty output
Hi everyone.
I'm new to the forum and quite new to LabView, so excuse me if my question is stupid.
I'm expecting a problem with a VI i did and i can't understand where i do wrong. I'm tring to filter a signal with a bandpass filter. I use the Butterworth Filter block but something goes wrong: the output vector is empty whatever i do.
Can someone figure where's the problem?
I attach a simplified VI with the part of the VI that doesn't works. Even this simplified version doesn't work.
Thank you vey much
Message 1 of 8
(3,644 Views)
Did you look at the explanation for the error code?  It indicates that the frequencies do not meet the requirement 0 < f_low <= f_high <= fs/2.
It appears that you are specifying the sampling frequency as 1/2000 = 500 microhertz. Is this what you intended?  It certainly violates the inequalities.
Lynn
Message 2 of 8
(3,638 Views)
Yes, that's correct.
I acquired the data at 2000 Hz. I made the spectrum of it and now i want to "extract" the frequencies between 10 and 20 Hz.
In this VI i've simulated this, but the "original" VI applies this operation to a real civil measurement done at 2KHz where i want to extract the time history of the resonant frequency to measure the dissipation coefficient.
Am I doing it in the wrong way?
PS: i didn't checked the error code because i couldn't find where to find it. Can you please tell me where you found the meaning of that error?
Message 3 of 8
(3,633 Views)
Sorry. I didn't understood what you were saying. I corrected the VI removing the 1/x block. (It was there since i used the same costant for the "dt" parameter in the waveform build tool)
Now it's true 10 < 20 < 2000 /2.
Moreover (in the "simple version") i switched the hi and the low cutoff freq.
Thanks for your help, it was a stupid error, but i could solve it.
For future use, where you saw the error explanation? It would have helped me...
Message 4 of 8
(3,627 Views)
Look at your inputs! Besides specifying the wrong fs, your high cutoff frequency is 10 and the low is 20. That is backwards.
Message 5 of 8
(3,624 Views)
Yes, i saw while you were answering 😉
Thanks really really much for your help, it was a stupid error, but i couldn't solve it.
Message 6 of 8
(3,621 Views)
Look at your menus. Help>Explain Error. Right below the LabVIEW Help.
Message 7 of 8
(3,618 Views)
You could also use the Bundle By Name to put the error code into the code and use the Simple Error Handler
Message 8 of 8
(3,606 Views)
