Error in GPIB connection
Hii Friends,
Can you help to solve this problem.
I intend to Use LV-2012 fro connection my SPEX-1702 monochromator to my PC.
After i installed the LV-2012, i installed Ni-VISa 15.5 version for windows following the instructions in ni website. But bow when i connec my device to the PC, the Ni-MAX shows a yellow exclamation near the device. I have attached the pic for the same. I have uninstalled and reinstalled the LV and Ni-VISa but the problem repeats.
Can you suggest me to solve the problem.
Thank you
(3,889 Views)
Your hardware didn't come with an installation CD? You need the manufacturer USB device driver as specified in the error message. The best thing to do is to contact the manufacturer. Look here for it and for a LabVIEW driver.
Ben64
(3,859 Views)
Hii Ben,
Thanks for the reply. Prior to connecting SPEX-1702, i have tried another GPIB devide Tektronix TDS 220 scope. I have installed the driver for it from the following page,
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=047216EC20B66FABE0440003BA7CCD....
But unfortunately, the same error turns up.
Pavan
(3,816 Views)
@Pa1_korea wrote:
Hii Ben,
Pavan
Why would you install a driver for a totally different instrument and expect it to work?  Would you expect it to work if you installed a mouse driver?
One thing that may have confused you is that Ben is talking about Windows-level drivers, not LabVIEW-level ones.
Still, I am wondering if it wouldn't be more expedient to ask a colleague to set it up for you, as I am unsure of your expertise in this matter.
Bill
CLD
(Mid-Level minion.)
(3,808 Views)
Accepted by Pa1_korea
You need to install the driver for the USB-GPIB controller.  That is the driver Windows is complaining about.
(3,774 Views)
