Error in IP Export Utility [LabVIEW 2020]
I am getting an error in exporting IP using the IP Export Utility, which says that a Xilinx Vivado error has occured and points me to the Vivado log in the iptemp directory.
The Error in the Vivado log reads:
Finished Part Resource Summary
Start Cross Boundary and Area Optimization
ERROR: [Synth 8-729] Failed to open 'C:/NIFPGA/iptemp/ipexport1D3D4902839C45B88E5F229A76CEED9C/.Xil/Vivado-2948-LAPTOP-JISTQGKE/realtime/tmp/////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////1DF777F8AF0.rtd': No such file or directory
ERROR: [Synth 8-787] cannot access rtd files in 'C:/NIFPGA/iptemp/ipexport1D3D4902839C45B88E5F229A76CEED9C/.Xil/Vivado-2948-LAPTOP-JISTQGKE/realtime/tmp/////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////', this is a FATAL ERROR! Please make sure the directory is readable and writable by the program and do not delete files from this directory while the program is running.
Any idea what may cause this error?
(2,207 Views)
Like the error message suggested. Is the C:/NIFPGA directory read-only?
(2,177 Views)
No. It isn't
Here is the snapshot of the error message
(2,127 Views)
any suggestions?
If I reduce the amount of logic in the FPGA VI, the problem goes away.
What I have understood from searching on NI and Xilinx forums, it looks to be a memory issue with Vivado. But, I am not sure how to fix it.
(2,072 Views)
How much RAM does your computer have?  What is the FPGA target?
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(2,039 Views)
16 GB RAM and the target is X410
(2,026 Views)
