Error in LabView lv51f1 Updataer
After install LabView lv51f1 updater, it is not possibel to
past text into text control or text constant.
After remove and install LabView 5.1 text pasting
are OK.
Geir Kåre Refstie
Scanmar AS
geirkarer@scanmar.no
(3,270 Views)
This sounds like a bug well worth fixing, but I don't see the problem
with English 5.1f1 on my Windows 95 machine. Text still pastes fine
from Netscape, Notepad, Word, etc, into front panel string controls and
block diagram constants.
You might want to bundle up your system info, LabVIEW language info, and
exact description of the copy and paste behavior and send it along to
NI's technical support.
John Lum
> are OK.
> Geir Kåre Refstie
> Scanmar AS
(3,270 Views)
