[W] LabVIEW 5.1 Application builder
After building an application and generating an installer, I get a
directory called DISKS and under that directory another directory
named RunTime, this directory contains 2.5Mb of files.
How do I distribute it on diskettes for my customer.
It seems that LabVIEW is getting more and more complex to use and to
install, now even LabVIEW applications gets more complex to install, I
think it misses the whole point of LabVIEW as being a simple software
and simple to use.
Ori Idan
O. T. Idan LTD. National Instruments Alliance member in ISRAEL
Email: ori@otidan.co.il
Home page: http://www.actcom.co.il/~otidan
Tel: +972-6-6262353 Fax: +972-6-6262405
Things should
be made as simple as possible but not simpler
Albert Einstein
(3,637 Views)
You should prepare two floppy disks.
One ( LabVIEW run-time disk 2) shall have data2.cab and the other (LabVIEW
run-time disk 1)
shall have all other files under the directory of Run-time.
Ted Takeuchi, Yokogawa Corporation of America
1919 S. Highland Ave., Bldg-A, Suite 330
Lombard, IL 60067 USA
Phone: 630-953-7571 Fax: 630-953-7579
E-mail ted.takeuchi@yca.com
www.yca.com
Ori Idan wrote in message
news:380D70D7.6AA74C24@otidan.co.il...
> and simple to use.
> Ori Idan
> Things should be made as simple as possible but not simpler
> Albert Einstein
(3,637 Views)
The knowledgebase covers this issue. It is not supposed
to do this, and is a bug in the application builder.
Greg McKaskle
(3,637 Views)
