Error in building an executable file
I want to create an .exe file of my VI. I have done complete setup to create an exe file (specifying correct source files, dependencies and others).
While building, i got the following error which is first time i am seeing. Previously i have created so many exes without any such kind of this errors.
(I have fully licensed application builder).
Error 1052 occurred at AB_Source_VI.lvclass:Copy_SourceItem.vi -> AB_Build.lvclass:Copy_Files.vi -> AB_Application.lvclass:Copy_Files.vi -> AB_EXE.lvclass:Copy_Files.vi -> AB_Build.lvclass:Build.vi -> AB_Application.lvclass:Build.vi -> AB_EXE.lvclass:Build.vi -> AB_Build.lvclass:Build_from_Wizard.vi -> AB_UI_Frmwk_Build.lvclass:Build.vi -> AB_UI_FRAMEWORK.vi -> AB_Item_OnDoProperties.vi -> AB_Item_OnDoProperties.vi.ProxyCaller
Possible reason(s):
LabVIEW:  The LabVIEW filename is invalid.
Possible reason(s):
Please do help me to resolve my issue.
Thanks and regards,
Sriram Iyer
(2,920 Views)
Hi Sriram,
Its sounds like the problem with the lvclass which you are using in the vi.
which LV version are you using? also good if you post your code.
(2,912 Views)
Have a look at this
(2,869 Views)
