Error in exe file
Hello every one
When running exe file in my clint pc i got error "This vi is not executable .the full development version of labveiw is req to fix the errors"
I am using labview professional 2012 Version
In my clint pc i runned a exe file it is running perfectly but after including a vi which reads hard disk serial no. the above error is coming in my clint pc please see the attached vi
Message 1 of 15
(4,516 Views)
Did you create an installer and installed in the client PC after including the new VI?
Message 2 of 15
(4,511 Views)
yes sir
I have created installer and installed
Message 3 of 15
(4,505 Views)
Where do you have the vi that you added later? I believe some files associated with the added vi is missing.
Message 4 of 15
(4,499 Views)
Message 5 of 15
(4,496 Views)
Please attach the vi in 2011 version.
Message 6 of 15
(4,491 Views)
see this vi in 11 version
Message 7 of 15
(4,488 Views)
Are the correct version of DotNET installed on your client PC? If not you will see this error.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 8 of 15
(4,474 Views)
Accepted by Nagaa
".NET, configuration files"  you'll want to go to that index in the LabVIEW help file
You will need to include a "MyApp.exe.config" file with this text
<?xml version ="1.0"?>
<configuration>
   <startup
useLegacyV2RuntimeActivationPolicy="true">
      <supportedRuntime
version="v4.0.30319"/>Or whatever version of the CLR you are using
   </startup>
</configuration>
Message 9 of 15
(4,466 Views)
Message 10 of 15
(4,442 Views)
