Error in invoking the build rule editor, LabView 2011
What version of LabVIEW do you have?
Under what circumstances do you receive the error? Does this occur with all projects?
Did you try uninstalling and reinstalling as well?
Anjelica W.
Product Marketing Manager
FlexLogger and TestStand
Message 11 of 16
(1,424 Views)
Problem solved by uninstalling & re-installing LabView 2011.
Message 12 of 16
(1,419 Views)
Is there any other way to fix this issue? I am facing this with LabVIEW 2017.
Nikitha
Message 13 of 16
(1,361 Views)
LabVIEW 2015 SP1
Tried the Repair - didn't work.
Uninstalled and reinstalled LabVIEW - Presto! Can now build executable again.
Message 14 of 16
(1,313 Views)
Dear all!
This also happened to my setup today:
I am no longer able to build applications with my setup (Win 10 64 bit, LabVIEW 16 32bit). When trying to open a build rule, I get a busy indicator for a few seconds. When trying to create a new build rule via the "New -> Application" context menu, I get the error message below. This also happens in an empty project and in a project that successfully build an executable yesterday.
(Beim Aufruf der Build-Regel-Engine trat ein Fehler auf. Prüfen Sie das entsprechende Provider-Verzeichnis auf fehlerhafte VIs. [OK])
I'd rather not reinstall everything.
Message 15 of 16
(1,184 Views)
So, the issue possibly fixed itself when I opened an older project where one vi would on loading detect a conflict in "clear errors.vi" and a few related vis from vi.lib, where vi.lib was in conflict with a version contained in a compiled executable on some network storage that I was remote debugging yesterday.
I resolved the conflicts by pointing to the vi.lib version and now the application builder launches again and I was able to successfully compile an executable.
This is a most fortunate turn of events and I can hardly contain my astonishment.
Message 16 of 16
(1,173 Views)
