Error in timing measurement
 I am trying to measure the turn-on time of two digital switches from the start of the current until the switches are high. my input signal is a 50 Hz sine wave. when I use the hardware timed single point mode, I am able to measure the time more accurately. However, when I use the continuous acquisition mode, I am not able to get the correct switch-on time. I think there is some problem with the code (which I could not find out). Please help me with this.
(966 Views)
Crosspost in German LabVIEW-Forum
(898 Views)
