LV 2024 Q1 (64): Cannot save VI, no error message appears, just does not save
When I initially load the project, everything appears to be fine.  I can create and save VIs with no trouble.
However, if I go to one of my classes and try to create a VI for override from the base class, I cannot save that VI, and from then on, I cannot save ANY VI anywhere in the project.
Once LabVIEW is in this state, when I try to save a VI that has changes, nothing happens.  No error message, nothing.  The asterisk remains on the title bar of the VI.
This looks like a rather severe bug in LabVIEW 2024 Q1.
Anyone else seeing this?
EDIT:
After completely exiting LabVIEW and re-launching, the problem seems to be resolved.  Previously, I had only closed and re-opened the project, and that did not resolve it, but terminating LV and re-launching did.
At least for now.  I suspect it will recur when I re-do the things that made it happen in the first place.
(1,255 Views)
I can confirm this issue (for LabVIEW2023Q3).
Workaround also seems to be to save the class which then asks you to save all unsaved new files within it. Which then works.
(1,133 Views)
