Error installing LINX - An internal VIPM 2020.3 (build 2540) Error has occured
Hey there - it seemed I was on the wrong or right track, depends on how you look at it.
When I installed LabVIEW, I didn't have the correct permissions. It could not write to disk.
So, I changed the permissions and now I am able to install packages.
Thanks for your help - Glen
Message 11 of 18
(1,999 Views)
Having the same problem. When you say you changed the permissions and can now install packages – what did you do differently beyond granting LabView/VIPM full disk access?
Message 12 of 18
(1,975 Views)
Just to be absolutely certain, you should NOT try to install LINX through VIPM.
Bill
CLD
(Mid-Level minion.)
Message 13 of 18
(1,972 Views)
I'm not sure if I was clear or not - but I'm running MacOS Big Sur.
I was able to get things running, but there are some weirdnesses:
  1. I had to manually modify all of the permissions in the System Prefs to get it to work. Maybe this is a new Big Sur thing - I've not had a Mac in 15 years.
  2. when I did finally get the LINX Toolkit installed, some of the palates where there, but the driver wizards would not work correctly. When I attempted to run it, I just saw the frontend VI.
    Any bright ideas?
Message 14 of 18
(1,962 Views)
Yep I'm also using Big Sur. I did finally manage to get the LINX toolkit installed and the LINX firmware generated/uploaded -- found this post helpful. But LabView crashes now that NI-VISA is installed, so I'm giving up for now. All works fine on a different computer running LV2020 on Sierra.
Message 15 of 18
(1,957 Views)
How many times do you have to drill it into me that you are installing on a Mac???  Jeez...  I apologize for having it take so long to seep through my thick skull.
I have to add that your patience is commendable.
Bill
CLD
(Mid-Level minion.)
Message 16 of 18
(1,946 Views)
Hey,
I am facing the same issue on Mac. I was wondering what system preferences you changed exactly to be able to install Linx in the end, please?
Message 17 of 18
(1,902 Views)
Hi there.
To get everything to work, I had to go into the System Preferences on my Mac, and manually change the settings to allow LabView and the VI manager to access the Mac file system.
I have not had a Mac since the Jaguar OS and there have been changes that I was not aware of.
I allowed the applications (LabView and VI Manager) to have access to the needed parts of my disk.
Make sense? I made a screen shot below. This is probably a mistake and I hit it with the biggest hammer I could find. It works, but it is probably not the preferred way. Elephant Gun/Mosquito analogy.
Message 18 of 18
(1,896 Views)
