Error message: Background operation already in progress
We used to use four channels for our DAQ, but recently I want to add one more channel. Then I just modify the program I used before, however, it always give this error message. The labview version I am using is 4.0.1.
Thank you!
(2,772 Views)
Hello;
The best way to troubleshoot that problem is to run one of the Labview shipping examples, with the same number of channels you have on your application.
IF everything goes weel, then start to change some of the acquisition parameters, such as the Sample rate and number of points to retrieve at a time.
Other than that, the only thing I can think of is a hardware failure.
Hope this helps.
Filipe
(2,772 Views)
