Error occured in MIG Software - 229771
I am encountering this error ( but it's occurence is not deterministic ).
My LabVIEW app has a command line mode and I'm running it from command line multiple times ( hundreds of times ).
And sometimes after hours of operation this error happens. I'm than forced to restart the system.
I am using NI DAQMX - 9.2.3
and the following NI PXIe cards in my system:
NI 5421
NI 6221
I do belieave it is the 6221 that is causing the issue.
OS is Windows XP
LabView is 10.0.1 ( Service Pack 1 ).
The only thread I've found that would have something similar is this one.
http://forums.ni.com/t5/forums/searchpage/tab/message?filter=location&location=Board%3A170&q=229771+...
But I do not have ANY Aanti Virus software running, that is why I decided to open a new thread.
I have had this system on several systems that have the same configuration.
I have taken the NI DAQMX drivers from the NI DS2 2011 Distrubution Disk but that has not fixed the problem.
If anyone has any ideas I would appreciate your comments.
(2,675 Views)
Things I have done:
Per suggestions from NI Support
1)Ran the procedure to clean the MAX Database
http://digital.ni.com/public.nsf/websearch/86256F0E001DA9FF86256FFD005B827C?OpenDocument
2)I've upgraded to DAQmx 9.3.5
3) Checked if during the installation of DAQmx the Administrator account was used
And I'm still stuck, I still keep getting the same error on ocasion.
If anyone has any suggestions I would much appreciate your help.#
Thank you,
Maciej
(2,624 Views)
