looping arrays
I have a while loop which is generating data with each iteration, and i want to store each element of data in an array, which will contain all data from the previous iteration, and I want to have access to this array from inside the loop as it is created. If I use build array it simply creates a new array with each iteration of the loop, and if i create the new array outside of the loop, it just pulls the original array back in when I add to the array from inside the loop. I am using lab view 6i. Thanks.
Message 1 of 10
(6,502 Views)
I would create the array outside the loop and then feed it through a shift register into the loop. The shift register will carry variables (in this case an array) from iteration to iteration. Inside the loop, I would add to the array using build array (right click on build array and choose Concatenate Inputs). I think that this would be the easiest way to accomplish this.
Rob
Message 2 of 10
(6,502 Views)
Is there any way of knowing ahead of time how many element will be in the array? The problem with the build array is that if the loop will be iterating many times it gets very inefficient because LabVIEW is having to constantly reallocate memory.
If you can calculate how many values will be in the output array (or if there is a theoretical maximum size for the data) a more efficient way of building this array is to create an array of the proper size to initialize the shift register Rob discussed and use the replace array element function to update the values. Updating an element in an existing array is much faster than building the array one element at a time.
The only complication to this technique is if you can't know at runtime exactly how many elements
the array needs and instead initialized the array with the theoretical maximum array size mentioned above. In this case, you might need to have a second register that maintains a count of the number of elements that were actually used, then when the loop terminates the value left in this shift register is used to split the data array to remove the unused elements.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 3 of 10
(6,502 Views)
I did not use build array, I instantiated the array outside of the loop, and then I used the while loop's counter to use "insert into array" in order to create the array, because this will automatically resize the array as needed. Is this still inefficient, or does labview have some sort of memory management going on behind the scenes when I use this. Theoretically I could calculate a maximum size, but it would have to be based upon the response time of a piece of hadware that I have yet to receive.
Message 4 of 10
(6,502 Views)
The problem with "insert into array" is that it inserts a new element at the location specified--which is as bad as the build array function. Updating elements (using the loop counter as the index) is really the way to go.
Mike...
LabVIEW Champion
Message 5 of 10
(6,502 Views)
How do you create an array outside the loop then using Shift reg feed it back into the loop.  I tried and I keep getting broken lines.  Isn't that like recursive?  Your feeding the info from the array back into itself.
Message 6 of 10
(5,938 Views)
Hi Mark,
that's not recursion - it's dataflow Smiley Wink
Message 7 of 10
(5,928 Views)
You added to a discussion that is 9 years old. Maybe you should hyave started a new question instead.
Your description makes no sense. Please attach your code or at least show us a picture of it.
(What kind of loop? What are "lines", "wires" perhaps?  feed back from where to where?)
Message 8 of 10
(5,926 Views)
At least he tried searching the forums for an answer. I agree he should have started a new thread once he didn't find what he was looking for but I do give him credit for trying to at least search for an answer.
Mark Yedinak
LabVIEW Champion
Message 9 of 10
(5,916 Views)
Yeah, thanks for the help and support.  The question asked was almost exactly the same one I had so I thought I'd give it a shot.
Message 10 of 10
(5,897 Views)
