Error occured in the call library function node in Trace32_PracticeCmd.Vi
Hi ,
I am trying to intergrate lauterbach (trace32) ; (Debugger) with labview . I have been provided the .dll and some functions that I can use by the manufacturer.
I am trying to "load" a file into my hardware . There is a sub vi that the manufacturer (Lauterbach) has made availabe to me , it is called "Trace32_PracticeCMD.vi" .Please find the Vi attached.
This Vi should allow a user to enter a command to perform for eg ."DO" and then subsequent Vi would allow me pass a path of the file with the filename and that is how I can load my file into my hardware .
This VI keeps throwing me an error . Please see the error attached.
I have read a lot of posts on the similar  error and have tried out all the suggestions that were listed but they are not helping me solve this .
I am also attaching the .dll file . Find attached
Please feel free to ask for more information.
Please suggest.
(3,113 Views)
Sounds to me like this is clearly Lauterbach's problem to fix. The error message indicates that there is either a problem in the DLL (which they wrote) or the VI calling the DLL (which they also wrote).
Are you sure the DLL is compatable with the version of Windows and/or LV you are using?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,093 Views)
Mike ,
 Thank you .
I know the dll is comptabile with the labview 2011 , that I am using. Since , I have the VI and the dll attached can we not try to debug the cause ?
I have contacted the manufacturer too.
Help appreciated !
(3,081 Views)
With this error a common solution is to check how the dll is called. Here are a few articles that address calling a dll. Definitely try changing the calling convention. I hope this helps with the first steps in debuging. It is good to hear you have contacted the maufacturer. They will most likely have a solution or example for you to work from.
http://digital.ni.com/public.nsf/allkb/7253D2F0D91F68058625752F005AB672
http://digital.ni.com/public.nsf/allkb/DCB90714981A1F148625731E00797C33
Good Luck,
ConnorM
(3,043 Views)
