05-12-2005 01:56 AM
10-20-2005 01:49 AM
Did you ever work out this problem? I am having a hard time connecting to my Olympus BX62 from LV at the moment. Seems to be the same problem described in this post.
Anja
10-20-2005 05:55 AM
Yup, we managed to solve the issue. I've attached a VI for you to try out. This VI only controls the shutter and filter turret. Give it a shot.
kian
10-20-2005 07:16 AM
10-23-2005 10:14 PM
10-24-2005 01:22 AM
Wow, it's incredible that Olympus provides so little documentation for these expensive microscopes. The shutter and filter turret might be enough for what I need, fortunetaly. Thanks a lot for helping.
Cheers, Anja
03-17-2006 06:57 PM
This message has helped me out a lot. A final comment is that, after reading the post I downloaded the olympus instrument driver .lld for LV 7 and begin to play with it. I found that all the functions operate correctly, if all the commands are terminated with a carraige return and line feed constants just before inputing into the OLXXX2 Olympus Command.vi (The posted solution for OLXXX2 initiate.vi has this incorporated, but performs the function of OLXXX2 Login.vi). Thank you for providing this forum. I hope this helps.
Josh Meisner
Texas A&M University
Biomedical Engineering
Veterinary Physiology & Pharmacology
04-13-2006 11:14 AM
Since the Carriage Return & Line Feed appending should be done to any command that is sent, it would seem more logical to me to only change the OLXXX2 Olympus Command.vi to append these two chars and just make sure that no part of the instrument driver does append the cr/lf characters already.
Josh Meisner
11-18-2007 09:43 AM
I'm having troubles working my Olympus IX81 microscope with LV8.2 . I downloaded the olxxx2 drivers, and repeatedly recieve the above error (BFFF0015) in the VISA read vi.
I've tried to raise the timeout but that doesnt seem to solve the problem. it read here that the VISA must be configured, but i don't know to what values.
Please, i've tried to solve this problem all day, but with no luck.
thanks in advanced.
11-18-2007 12:12 PM
