Error: "BFFF0015 Timeout expired before operation completed."
Thank you for responding,
can you tell me please what to try out in hyperterminal? what should i type?
Message 31 of 38
(3,177 Views)
You should type one of the commands that is given in one of the earlier posts to this this thread, one of the commands that is in the driver, or one of the commands that is in the manual for the instrument.
Message 32 of 38
(3,167 Views)
I am trying to establish communication via an RS-232C port between my computer and an IX81 microscope using Labview without much success. Actually I am connected to the microscope control box (IX2-UCB). I downloaded the olxx2 VI set. You were mentioning that we just had to add a string CR LF somewhere in the program. Can you be more precise?<
Thank you in advance,
Pierre
Message 33 of 38
(2,993 Views)
Hi Josh,
This forum was quite interesting. I am still struggling trying to get the IX81 working with LabView. Would you mind sharing with me your new Command.vi described in your e-mail?
Pierre
Message 34 of 38
(2,981 Views)
If you had checked, you would have seen that Josh has not logged in for two years.
If I remember correctly, what you want to do is pretty trivial. The function has a string input wired to a VISA Write (or womething equivalent). Instead, wire this to a concantanate string function and wire the CR and LF constants to other inputs of the concantanate string function. The constants are on the string palette. Wire the output of the concantanate string function to the VISA Write.
If you continue to struggle, attach the VI you are trying to modify.
Message 35 of 38
(2,975 Views)
Hi Dennis,
Sorry for the mistake...
I already tried the Concatenate function, but without too much success. I have to admit though that I am not the greatest Lab View expert.
I used Portmon to spy the Olympus software (in my case, "In Vivo"). I tried different combinations with the Concatenate function to try to mimic the real command that is sent to the microscope, e.g.:
"1SHUT1 OUT.." (finishes with two points)
Here is one combination that I tried:
"1SHUT1 OUT" (string) + "\n\r" (string)
Unfortunately that was not successful
Maybe I am missing something obvious...
Thank again for your precious feedback and expertise,
Pierre
Message 36 of 38
(2,961 Views)
Attach what you've done (The 'Attach' link right below the message body). I don't have the instrument but maybe I can see something you did incorrectly.
Also, verify your settings and serial cable by using Hyperterminal first. It does no good to try LabVIEW if you can't communicate with Hyperterminal. The instrument settings may not match or you could be using the wrong type of serial cable.
Message Edited by Dennis Knutson on 10-30-2008 08:12 PM
Message 37 of 38
(2,956 Views)
Does anyone have the Olympus Command.vi file with the correct fix for programming an Olympus IX2-UCB connected to an IX81-ZDC2?  I could not follow what needed to be changed within the subVIs in terms of the carriage returns and line feeds.  Any help would be appreciated as well.
Message 38 of 38
(2,185 Views)
