Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results forÂ
Search instead forÂ
Did you mean:Â
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Error when Bridview Starts
none None
Member
‎10-17-2003
09:11 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Error reads at Bridgeview startup
"Unable to access the CCDB
The application directory has been modified
Correct the directory or restart the application"
0
Kudos
Message
1
of 4
(3,019 Views)
Reply
Re: Error when Bridview Starts
AndreOliveira
Member
‎10-20-2003
01:32 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Did this error came up after a particular event ? This error comes up when you simply launch BridgeView ?
What is the Operating System ?
Andre Oliveira
0
Kudos
Message
2
of 4
(3,019 Views)
Reply
none None
Member
Author
‎10-21-2003
11:29 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
The error comes up simply by launching Bridgeview.
It is happening on two OS's, WIN98 and NT4.0.
Thanks.
0
Kudos
Message
3
of 4
(3,019 Views)
Reply
none None
Member
Author
‎10-21-2003
11:30 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Sorry, I should have told you it is Bridgeview 2.0. With Bridgeview 1.1, the error does not happen.
0
Kudos
Message
4
of 4
(3,019 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
