Error when deploying executable onto Windows Mobile 5.0 Pocket PC
Hi All,
I got the following error message when trying to deploy my executable built with LabView PDA module 8.2.
Can any one help?
Cannot find 'Button Input VIs - Pocket PC'  (or one of its components).  Make sure the path and filename are correct and that all the required libraries are available.
hellolv
Message 1 of 9
(6,509 Views)
hellolv,
When do you get this message?  When you build if for the PDA or while deploying it?  I have seen a similar error message that I have been able to resolve by simply restarting my computer, so that is the first thing I would try.  I would then open the project, right-click on the Build Spec and select Build.  Then right-click and select Deploy.  This will separate the two and we can get an idea when the error is happening.
Let me know! Thanks!
Andy F.
Message 2 of 9
(6,471 Views)
Hi Andy,
I built an executable and tried to open it on a Windows Mobile 5.0 device when the error message popped up.
Do you know what the best tutorials for PDA module?
hellolv
Message 3 of 9
(6,465 Views)
We are facing similar problem when trying to deploy the application to ARCOM viper winCE based device.Please letus know is there any settings to be done with device to correct this issue?
Message 4 of 9
(5,866 Views)
Hi aradhya,
I hope you are doing well today! It seems to me that this device has an ARM compliant chip on it. Could you please confirm that for me? What exact steps are you taking to deploy the executable on the device? Also, what sort of functions are you calling/using in the VI itself?
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
Message 5 of 9
(5,847 Views)
The PDA we are using has PXA255 ARM device.Please find the link below for more info about the device we are using:
I followed the procedure in the NI link  http://zone.ni.com/devzone/cda/tut/p/id/5361
,instead of using device emulator i used WINCE POCETPC device as target. then build,then deployed the application to device.
We tested with other (ATMEL SAM9261 evaluation kit) WINCE based PDA Device,it worked fine with it.
Aradhya
Message 6 of 9
(5,841 Views)
Hi Aradhya,
Can you please try instructions at the following link and let me know if it works for you?
Why Can't I Run My Pocket PC 2003 Application Containing PDA Button Input VIs on the Emulator?
Adnan Zafar
Message 7 of 9
(5,821 Views)
Hi Adnan,
I tried it,its still the same.
Aradhya
Message 8 of 9
(5,805 Views)
I will have to look more into this issue. Can you please attach a screenshot of the error you are getting?
Adnan Zafar
Message 9 of 9
(5,782 Views)
