Error when integrate .fc file in fuzzy program
How to add .fc file in .vi?
I already check the .fc file name is correct.
(2,543 Views)
Have you verified your constructed path with an indicator to make sure that it is correct right before it is loaded? Also, have you tried using a dialog to select the file to see if that works?
-Zach
(2,524 Views)
