02-02-2010 06:17 AM
How to add .fc file in .vi?
I already check the .fc file name is correct.
02-03-2010 10:25 AM
Have you verified your constructed path with an indicator to make sure that it is correct right before it is loaded? Also, have you tried using a dialog to select the file to see if that works?
-Zach
