Error when trying to install executable generated by Labview
Did you add the runtime system under additional installers?
Message 11 of 12
(515 Views)
Hi, barney,
Probably you haven't include LabVIEW Run-Time (or may be other runtime) into your installer. may be some VIs are broken (missing DLLs, etc).
What I would like to recommend - use Virtual Machine for testing installers. I using VMWare (as far as I kow there are other solutions available on the market)
So, it takes 30 seconds for copy fresh OS Image "out of box", then 30 seconds for copy installer on  it, then few minute for install and quick check. These few minutes can save hours for you and for your customer.
Andrey.
Message 12 of 12
(505 Views)
