Error when using UPDATE SQL command
Using DB Connectivity Toolkit, I am trying to execute the following SQL command:
UPDATE ItemTable SET KGU? = 'True' WHERE ProductID = 'S1'
I get this error:  "Conn Execute.vi<ERR>Incorrect function. in Conn Execute.vi"
Attached is a JPEG of the code.
Any help would be greatly appreciated.
Scott
Message 1 of 11
(5,933 Views)
Try putting enclosing your column name KGU? in square brackets like
UPDATE ItemTable SET [KGU?] = 'True' WHERE ProductID = 'S1'
and see if that helps you.
David
Message 2 of 11
(5,917 Views)
David
Message 3 of 11
(5,917 Views)
David,
Thanks for replying.  I tried the brackets around KGU?, it did not resolve the failure.  Any other ideas?
Scott
Message 4 of 11
(5,911 Views)
Just had another look and you are missing a semi-colon to terminate the command
UPDATE ItemTable SET KGU? = 'True' WHERE ProductID = 'S1';
I would keep [KGU?] in just in case the SQL interpreter thinks the ? is an operator instead of being part of a field name.
Message 5 of 11
(5,905 Views)
I tried the semicolon too ... same error message.
Scott
Message 6 of 11
(5,901 Views)
Scott
Have you tried to run your UPDATE query in MS Access like this?
Open your database and create a new query in MS Access then change to SQL view and paste your query there. Then execute it and look at the errors, if any.
I always build design my queries in MS Access query builder then transfer the SQL to Labview where I then use format into string or the build text express vi to create variable queries.
Could you post your vi?
David
Message Edited by David Crawford on 04-27-2006 02:56 PM
Message 7 of 11
(5,899 Views)
David,
It works now!!
I changed the KGU? field name to KGU and it worked!  I guess the ? was a problem.
Thanks for your help.
Scott
Message 8 of 11
(5,894 Views)
Brilliant, well done.
So was the field name in the database just "KGU" and not "KGU?" then?
David
Message 9 of 11
(5,891 Views)
No the field in the database was really KGU?.  Adding the brackets [KGU?] appears not to "fix" the fact that there is a ? in the field name.
Scott
Message 10 of 11
(5,888 Views)
