How can I use a USB camera with cRIO 9022. Please see my strange problem.
        I would like to use a USB camera with NI cRIO 9022. I used the same USB camera with NI USB 6216 DAQ device and developed a VI(within a PROJECT and outside it). So, It is working fine with NI USB 6216 device when I use the Vision Assistant Express VI and gets detected in its Initialization Window.  Please see JPEG File 3 where I get NO ERROR.
        I am facing a problem when I want to use it with NI cRIO 9022. What exactly I am doing in this case is:
1) Create a NEW PROJECT
2) Add Targets and Devices(NI cRIO 9022)
3) Use the Scan Interface mode
4) Create a NEW VI under the cRIO 9022 device
5) Use a Timed Loop(Synchronized with Scan Engine) for continuous Data Acquisition and Sending from the Analog I/O modules.
6) Use the Vision Assistant available through the NI Vision Acquisition 2010 Module(I get STUCK HERE! The Express VI opens the Initialization Window, but I don't see the USB camera like in JPEG File 3)
I am facing difficulties with this HOST COMPUTER, cRIO implementation differences. On my host computer I have the software packages as shown in JPEG File 1, and on my cRIO 9022 as shown in JPEG File 2.
Can someone guide me how to overcome this and get the USB camera detected when I am using NI cRIO 9022?
NOTE: If this is a problem with software mismatches on HOST and NI cRIO 9022 device, please see JPEG Files 1 and 2 for available software and Host and cRIO 9022.
Thanks.
Amar.
(3,350 Views)
Only GigE comms are supported on the cRIO Real Time OS. Have a look at the following:
Machine Vision on NI CompactRIO and Single-Board RIO
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,337 Views)
