Showing results forĀ
Search instead forĀ
Did you mean:Ā
Error while generating Report in PDF using ActiveX
The VI I am using is given in the forum https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kGF9SAM&l=en-IN.
While running the VI I am getting an error with error code -2147467259, and message "Exception occured in Microsoft Word: The export failed because this feature is not installed.Help Path is C:\Program Files (x86)\Microsoft Office\Office12\1033\WDMAIN11.CHM and context 25726 in Save File to PDF.vi->GeneratePDF(ActiveX Method).vi".
I am using labview 2019 and I have also installed report generation toolkit 2019, the VI is attached here.
(5,209 Views)
Kindly help is solving this error
(5,189 Views)
Do you have Microsoft Office installed (and activated)?
(5,180 Views)
Yes I am using office 2007
(5,163 Views)
Accepted by topic author msabah38
According to this thread, you need to have some add-on installed in Office 2007 in order to export to PDF.
Don't know what the add-on is, because the link is broken, but it's a good start.
(5,158 Views)
Thanks for the thread, I had to install add-in for microsoft office2007 called as "Save as PDF", and it worked. The setup for add in can be found in the link https://filehippo.com/download_2007-microsoft-office-add-in-microsoft-save-as-pdf-or-xps/ .
After installing the add-in a new icon appears in MS word as shown below.
And now the VI run without any errors. Thanks.
(5,141 Views)
