Error while opening an excel file via labview
(2,664 Views)
It appears that the New Report .vi only accepts the .xlt template format and not .xltx as one would commonly expect. I am currently working to determine for sure that this is the case, but it does run (mostly) properly on my end if you make that change.
When I say mostly, I mean there are a couple other minor issues with your code. First the first frame of your sequence structure is really accomplishing anything. If your intent is to open a reference to the excel template, there is no need because the New Report .vi does it automatically.
Second, you will need a file path of some sort wired in to your Save Report to File .vi or else you will get a different error message after fixing the .xlt issue. I am currently researching whether this should be marked as a required terminal instead of recommended so that it not being wired would result in a broken run arrow rather than an error.
Let me know if these suggestions resolve your issue, or if I can provide further input on what you are doing in your first frame. I will touch base again once I determine whether these are expected behaviors or bugs.
(2,598 Views)
thanks a lot  OlliesCamel
i solved the problem of getting each row in a different page,the problem that i have now,is how can i get for each row it's own histogram and this histogram has to contain 2 types of values,values of that row and the values of all the rows(the average)so i can make the comparison between a user and the average.i posted that issue here
(2,595 Views)
