Error while opening labview 2016
Dear all
when i run labview 2016 it gives error. error code attached here.
thanks,
asif
(4,559 Views)
Did it ever open okay?
Bill
CLD
(Mid-Level minion.)
(4,507 Views)
hi
no, i just installed labview and opened first time giving this error.
Asif
(4,487 Views)
first some simple things:
  • Did you reboot after installing?
  • Are you running any unusual security software?
  • Did you only install plain LabVIEW or any other parts (drivers, modules, toolkits).
(4,474 Views)
Accepted by topic author Asif138
(4,460 Views)
1- i rebooted after installation.
2- Not running any unusual security software
3- i also installed DSC Module with labview.
asif
(4,452 Views)
Did you try the solution suggested in the link supplied?  (A different link, but very similar is here.)
Bill
CLD
(Mid-Level minion.)
(4,431 Views)
