Error
 I ues Labview for my experiment. After a frequency sweep, I face an error, not always but %80 of the experiments. So, I mean the program doesn't have any error. The frequency sweep range is 40-70 Hz in 120 steps. The sampling rate is 90000 samples per second, I record data for 1 second every step. So, the result matrix is huge(90000*120). The RAM of the laptop is 4GB, could it be the reason?
I've attached a screenshot of the error to this email.
Vahideh
Message 1 of 32
(6,678 Views)
Is there a reason for such a high sampling rate when a sampling rate two orders of magnitude lower would suffice?  (i.e., Hundreds of samples per second and not tens of thousands?)
Bill
CLD
(Mid-Level minion.)
Message 2 of 32
(6,658 Views)
Yeah, you are taking way too many samples.  Per Nyquist, in order to see a 70Hz signal, you need to sample at least 140S/s.  I like to use more like 10x instead of 2.  So change your sample rate to more like 1kS/s.  This will reduce the amount of memory you are using by 90x.
Message 3 of 32
(6,653 Views)
Maybe catching transients at the kHz level, come to think of it?
Bill
CLD
(Mid-Level minion.)
Message 4 of 32
(6,650 Views)
Many thanks for your replies, actually with lower sampling rate, I can'i obtaon good result, So I have to increase the sampling rate, because only in this case my results are in the acceptable range.
Message 5 of 32
(6,636 Views)
We are thinking of buying a new PC with 32Gb RAM and a good processor.but I thought, maybe it wouldn't a good solution. As you that type of PCs are expensive.
Message 6 of 32
(6,632 Views)
That's impossbile.  There's something wrong with the way you are acquiring the signal if that is the case.
Bill
CLD
(Mid-Level minion.)
Message 7 of 32
(6,630 Views)
So, what are you suggesting? I can perform the experiment without any problems, but sometimes I face this error 😞
After the experiment, when I import those matrices to MATLAB for process, it takes 5-6 minutes time. So I'm thinking of RAM
Message 8 of 32
(6,626 Views)
I think you have to think about why you can't capture a good signal using the Niquist standard?  (Sampling rate twice the frequency.)  Or even 3x or 4x (280 S/s)?
Edit - or even 10x as was suggested.
Are you actually trying to capture something out of band?
Bill
CLD
(Mid-Level minion.)
Message 9 of 32
(6,618 Views)
It's sweep, the frequency changes from 40-70, so you mean I adjust the sampling rate to 140.?
Okay, I'm going to try it, though I've tried 1000 before.
Message 10 of 32
(6,612 Views)
