Error
First i install the ka view 2020 after that i uninstall it and delete all the files in programme file and programme ×86
And now i can't install the labview
Message 1 of 16
(3,710 Views)
What is "ka view 2020"?
Message 2 of 16
(3,667 Views)
Sorry labview 2020
Message 3 of 16
(3,664 Views)
Why did you delete program files?
Why didn't you just uninstall from the beginning?
Message 4 of 16
(3,656 Views)
When I install the lab view my laptop working slow so I think because of LabVIEW that happning so I uninstall it and delete the programme files
Message 5 of 16
(3,651 Views)
What should I do ??
Please tell me plzzz
Message 6 of 16
(3,589 Views)
The chances are very good that you will not be able to install LabVIEW until you completely rebuild your PC's software, starting with backing up all of your files, reformatting the hard drive, reinstalling Windows, reinstalling all the other software you want to use (such as Microsoft Office), restoring your Documents, and when everything else works, installing LabVIEW.
LabVIEW is a very complex, fairly large Programming Environment.  It can take the greater part of an hour to install.  As with most Windows Programs, bits and pieces of it are inserted into the Windows environment, with files scattered around the disk (not all of them in National Instruments folders), and multiple (!!) entries in the Windows Registry.  Uninstalling LabVIEW can take as long, or even longer, than the installation, as NIPM, which serves to both Install and Uninstall, has to "find all the pieces" and remove them properly.
You have, unfortunately, corrupted this delicate balance by deleting files that the Installer/Uninstaller needs to properly Install or Uninstall LabVIEW.  I have encountered this situation in the past, and a reformat/rebuild was the only procedure that worked.
Bob Schor
Message 7 of 16
(3,580 Views)
Thank you so much
Message 8 of 16
(3,577 Views)
What kind of error do you get if you try to reinstall? How did you uninstall? (Typically you would remove all using the NI package manager, then uninstall the NI package manager, in that order). What files did you "delete"? What is the meaning of "slow"? How do you measure that? (There were a couple of windows updates recently, and they will also make your computer temporarily slow).
It really helps of you would describe your problem in detail. Can you show us a screenshot of what happens if you try to reinstall?
Message 9 of 16
(3,546 Views)
First I uninstall the NI package manager ( use of control panel) after that delete alltall files of National Instruments (  in OS folder program files and program files ×86)
Now there is nothing show of this application in control panel
Slow means when I don't install the labview my laptop start in 30-40 sec but when I install the labview my laptop take time up to 4 -5 minutes so I think because of labview this is happened so I uninstall it
I search any other files are present or not ( in laptop ) but I couldn't find it
I atteched the photo what error I  get when I try to install the NI labview
Message 10 of 16
(3,538 Views)
